Vlookup Function
The VLOOKUP function in Excel is a powerful tool for searching and retrieving data from a table. VLOOKUP stands for “Vertical Lookup,” which means that it searches for a value in the first column of a table and returns a corresponding value from a specified column in the same row.
Goals
Please follow the directions given below, which include downloading the Excel worksheet required to perform the challenge tasks. Once you have completed the download, proceed to take the challenge and test your skills.
Task
Find the Product Code for every item based on the
information provided in table 3.
Compute the Price Change, $ for each
item by comparing the 2019 data from table 2 with the
previous year’s (2018) data from table 1.
Compare the obtained values with the data in column I.
Calculate the percentage Price Change in 2019
compared to the previous year (2018) by dividing the
2019 value by the 2018 value and subtracting 1.
Compare the resulting values with the data in column J.
Submission
Reply to this post with your formula code and solution file. Please be sure to blur or hide your formula code.
Period
This workout will be released on Monday May 15, 2023 , and the author’s solution will be posted on Sunday May 21, 2023 . Challenge #15.xlsx (8.3 MB)
I taken the change column within the table. If the change is a positive number (increase from 2021) then the % must be a positive number not a negative percentage.
Thank you for participating in the Excel Challenge related to Vlookup Function! I hope you found this challenge to be a fun and engaging way to improve your Excel skills and learn more about how to work with Vlookup Function in Excel.
