A question re amendment 2. Handling records without a due date. Approx 2/3 of the issues don’t have a due date. Does this mean that we should be changing the status column to “Work in Progress” for all of these tickets? Might make the data look a bit odd with so many incomplete tickets?
Hello @Luke ! I do not know if there is a best approach to solve this, but in correcting the status for issues without a due date I am taking into account multiple parameters.
For example, for an issue that does not have a due date but has a resolved date, I am considering a Status like “Resolved but Incomplete”. If the issue does not have a resolved date, due date & assignee I consider as status “Unassigned” etc etc. You can create as many scenarii as you want. It all depends on the analysis you want to do, the message you want to transmit and the story you want to buid. Good luck!
Hello
I have a question.
In the column “Status”, what is the difference between Open and Openend?
@alejos1971 I think the employees are also bad in grammar
MudassirAli
Is there a way to get the unique ranking with RankX?
I am ranking tickets raised by Status but getting the duplicate rankings. I worked on a visual whole day and can’t get it to work in the end just because of the rank ties. If it’s not possible then I would have to redo everything
I actually did a video on this issue a few months ago. Hope you find it helpful.
- Brian
I think @alexbadiu’s response is 100% spot on. I happen to know that other than the names, this is a completely real-world dataset. Thus, I think analyses of anomalies in recording/reporting, deviations from best practices, etc. fall into the brief category of “identifying patterns for recurring issues so we can identify which areas may need management intervention”, and would be well-received by the client.
– Brian
Thanks a lot for the solution. Really loved the way how you built out the story and showed how duplicate #1 ranks can be damaging
I will try this one today.
Thanks - I had a lot of fun making that one. Hope it provides what you need for your analysis. I am beyond intrigued to see the visualization you spent an entire day on. Is this a new Charticulator visual you cooked up in the lab?
- Brian
@BrianJ
I am just lost in creating own made custom visuals and have been going back and forth to get what I need and have successfully managed to pull off some cool visuals. The best thing that I like about Charticulator visuals is that you can disable the auto-size for axes, the option that I had been looking for in various challenges.
I have been trying to get the visuals similar to Tableau that allow parallel coordinates to design outstanding looking visuals. I hope the Power Bi will give the option to design your own visuals inside the service. Will have to wait till then.
Watching the amazing stuff that you and @datazoe are doing with this tool, it really does make me wonder why Microsoft hasn’t invested more in it, publicized it more, and integrated it with the desktop client? It seems the one area where Tableau still has a substantial advantage over Power BI is in visualizations, and this could really help close that gap.
Have you seen this paper below by the Charticulator developers?
https://www.microsoft.com/en-us/research/uploads/prod/2018/08/Charticulator-InfoVis2018.pdf
In it, they also have a really cool gallery of a dozen custom visuals they designed using Charticulator.
Can’t wait to see your submission for this challenge.
– Brian
@BrianJ
Yes, I did see the paper but still not many material around to learn from. So far what I have noticed is that there is some problem in re-using the custom made visual for a slightly different dataset. This can easily be fixed by Microsoft and I am also surprised why they didn’t invest more after rolling it out.
So far I have tried almost every visual shown in the Charticulator Gallery to see what will work out in the recent challenge.
I hope I can finish the challenge on time
I tried but couldn’t seem to make it work. Attaching the file if anyone can get the unique ranking to work.
Unique Rank.pbix (169.8 KB)
Thanks!
@MudassirAli Does this help:
@AntrikshSharma
Wow what kind of a sorcery is this?
It works like a charm
Why Microsoft can’t get the option embedded in RankX function for unique ranks? This could make the life easier.
I need another magic spell for you to cast. Greedy Greedy
I am looking for the measure/solution that could work with line chart to dynamically show the trend related to the separate categories. For example say the categories are A, B,C & D. Ranking of the categories will change based on different filter selection. A could be #1 rank in Jan but # 2 in Feb, therefore, I want the line chart to show the trend based on rank #2 in Feb.
Page-level filters can be used to dynamically update but this won’t work based on the type of visualization I am looking for.
In simple words, in the Bar Chart, A is at top so I want to show the line chart for A only, B for B, C for C etc.
Thanks a lot again for the solution.
@haroonali1000 (or anyone) - this is probably a dumb question - but the due date is 10/25 PST. I’m assuming this is by anytime on Sunday - California time, correct? I wasn’t sure if there was an exact time and just trying to plan accordingly. Thanks,
Tim
My submission for this new challenge, I missed the last one due to personal reasons.
So submitted little early this time. As always, looking for all your views and suggestions.
Link:
Working file attached, so please check and provide your constructive feedbacks.
So much to learn from you all.
EDNA challenge 8_Mohammed Ali.pbix (484.2 KB)
My submission for this new challenge, as always, looking for all your views and suggestions.
EDNA_CHALLENGE_8_JIRA_GIFTED.pbix (327.1 KB)
Hi All.
Here is my submission for eDNA C8.
(Edit: 1. added note after PTW link)
(Edit: 2. added screenshot of SLA supporting table)
Thanks to @datazoe who noticed and commented that the Python Ring Chart was not displaying properly when using PTW; apparently neither R nor Python visuals are supported when using PTW
Here are the notes I kept during development:
NOTES:
What I liked:
- I’ve been gravitating towards simplicity for the last few challenges (even while producing complex but visually compelling reports), and feel that I’ve found my “happy place” in this challenge submission, with its standard white background and simple, small, and familiar navigation
- Rather than choosing a colour palette myself (I’m an engineer by training, so by no means would I impose my graphical sense on others), I went to the colour experts and used a palette they had chosen; I really like the results and it certainly freed-up time for me
- I’m happy with the categorization of priority, status, and type into 3 groups each, and feel that the simple column charts on the summary page of the report effectively show trends without becoming overwhelmed by detail
- I’m happy to have implemented at least a partially-successful Ring Chart in Python; I can see great opportunities for future Python visual development as my Python and statistical knowledge both increase
- I’m pleased with the results of avoiding blanks in numerical measures by appending a “+ 0” onto the end of each; I can see this becoming a standard practice with me
- I’m pleased with finding a method of easily working with custom smart narratives (write text first with placeholders for the measures, write the measures, replace the placeholders with the measures [which are now the “values”] [and name the variables to match the measures], save the values, then last of all format the values)
What I didn’t like/what needs more work:
- I was not able to figure out (in the time I allowed myself for this challenge) how to add the data labels for the percentages themselves into the Python Ring Chart, and so resorted to a “hack” by adding 3 standard Power BI Card visuals, 1 with each of the 3 percentages; a full implementation in Python would have been preferred
- I did figure out how to implement a 2-item dataset (category, value) sample into a Python Ridge Plot, but was unable able to figure out (again, in the time I allowed myself for this challenge) how to properly extend the sample into a Python Ridge Plot with a 3-item dataset (project, date, issue count)
- I’m discouraged I didn’t get the opportunity to explore the “watchers” further (in the time I’d allotted myself for this challenge); I figured out the data model well, but didn’t have time to analyze it properly (or actually at all)
- I’m discouraged I didn’t get the opportunity to explore the parent-child hierarchies further (sigh, again, at the risk of repeating myself, in the time I allotted myself for this challenge); again, I figured out the data model but ran out of time before I could explore this in visualizations
Inspiration:
- I was inspired by the simplicity of @sam.mckay’s eDNA Challenge #6 submission, with its solid-colour sidebar and white body, and wanted to challenge myself to take this as far as I could and try to minimize the “chrome” as much as possible
Power BI Challenge 6 - Insurance Complaints - #120 by sam.mckay - Ever since I saw the use of multiple overlapping donut charts in @Walter’s eDNA Challenge #2 submission, I’ve been on the lookout for an easy way to re-create this.
Power BI Builds 2 - Customer Insight - #35 by Walter - With my son taking an Introduction to Python programming course in university this year, I seized the opportunity the explore Python visuals inside Power BI and am pleased with the results. The method of “attaching” Power BI datasets and measures to a Power BI Python visual is the same as for other visuals (i.e., drag-and-drop). Once the data is available within the Python visual, however, the complexity begins and a thorough knowledge of the use of Python mathematical packages is in order; I’ve just scratched the surface and would need to make a concerted effort to improve my statistical chops before attempting to use this visual in a production report.
Setup:
- used Power BI Desktop October 2020 release (Build 2.86.727.0, date published 10/19/2020)
Goals:
- challenge myself to try and minimize the Chrome as much as possible, using simple sidebars created in PowerPoint and familiar navigation (same as iPhone/iPad and Microsoft Teams, for example)
- to allocate a much higher percentage of my challenge preparation time to data preparation and analysis rather than to visualization niceties/themeing (in sharp contrast to my previous challenge entries)
- to gain more experience with the Smart Narratives visual
- to gain more experience on how to use Python visuals within Power BI
- to gain experience handling Parent-Child hierarchies in Power BI
Assumptions / Characterizations:
- this was my first time working with a JIRA dataset, so researched standard workflows and statuses to assign the available statuses to one of the three what seemed to me) standard status categories: To Do, In Progress, and Done. The assignments used in this analysis were:
- To Do:
- Accepted by Assignee, Awaiting IT Security Course Completion, Open, Opened, Pending, Waiting for approval
- In Progress:
- Awaiting Verifier, In Progress, Verified, Waiting for customer, Waiting for support, Work in progress
- Done:
- Canceled, Closed, Completed, Done, Resolved
- To Do:
Here’s the code for the calculated column:
Status Category =
VAR _DoneList = { "Canceled", "Closed", "Completed", "Done", "Resolved" }
VAR _InProgressList = { "Awaiting Verifier", "In Progress", "Verified", "Waiting for customer", "Waiting for support", "Work in progress" }
VAR _ToDoList = { "Accepted by Assignee", "Awaiting IT Security Course Completion", "Open", "Opened", "Pending", "Waiting for approval" }
SWITCH( TRUE(),
'Status'[Status] IN _ToDoList, "To Do",
'Status'[Status] IN _InProgressList, "In Progress",
'Status'[Status] IN _DoneList, "Done",
BLANK()
- I renamed [Priority] to [Description], then assigned a shortened [Priority]
Here’s the code:
Priority =
SWITCH( TRUE(),
Priorities[Description] = "Highest", "P1",
Priorities[Description] = "High", "P2",
Priorities[Description] = "Medium", "P3",
Priorities[Description] = "Low", "P4",
Priorities[Description] = "Minor", "P5",
BLANK()
- I assigned the 5 priority levels into 3 priority categories as follows:
- High: Highest, High
- Medium: Medium
- Low: Low, Minor
Priority Category =
VAR _HighList = { "Highest", "High" }
VAR _MediumList = { "Medium" }
VAR _LowList = { "Low", "Minor" }
SWITCH( TRUE(),
Priorities[Description] IN _HighList, "High",
Priorities[Description] IN _MediumList, "Medium",
Priorities[Description] IN _LowList, "Low",
BLANK()
– I assigned the types into 3 type categories as and used a calculated column to implement this as follows:
Here’s the code:
Type Category =
VAR _BugList = { "Break/fix Response", "Corrective Action Plan" }
VAR _TrainingList = { "Internal Process", "New User Request" }
VAR _GeneralList = { "POA&M Milestone Subtask", "Service Request", "Service Request with Approvals", "Sub-task", "Task" }
SWITCH( TRUE(),
Types[Type] IN _BugList, "Bug",
Types[Type] IN _TrainingList, "Training",
Types[Type] IN _GeneralList, "General",
BLANK()
Python Notes:
- as noted above, a thorough knowledge of the use of Python mathematical packages is required to effectively use the Python visual within Power BI
- for the Ring Chart, the pandas, matplotlib, and numpy package libraries were used to explore modifications to and extensions of a standard one-level donut chart as a 3-level ring chart
- (didn’t get a satisfactory implementation, so left the Ridge Plot out of the report, but am including my notes anyway for posterity) for the Ridge Plot (or Joy Plot or Overlapping Area Chart), the pandas, matplotlib, numpy, and scipy package libraries were used to explore the modifications to a standard area chart
- the Python visual is interactive and respects filters and slicer selections from other Power BI visuals, but my understanding is that each time the Python visual has to be redrawn (i.e., after a dataset change), the underlying data is written to disk as a CSV file and is then “pulled” back into the Python visual as a static screenshot. As such, tooltips are not available.
- I am a verbose coder, and a Python neophyte, so I don’t pretend that my coding is representative at all, but for the Ring Chart only required 32 lines of code were required (after comments and whitespace were removed)
- although legends are available in the handful of Python charts and plots I sampled, they are quite different in layout than those in standard Power BI visuals, and standalone standard Power BI visuals should probably be used to generate legends consistent with the other visuals in the report
General:
Setup:
- sourced blue-based colour theme from https://www.pantone.com/color-intelligence/color-of-the-year/color-of-the-year-2020-palette-exploration
- used [Just Color Picker] to grab HEX codes
- used Power BI Tips Theme Generator https://themes.powerbi.tips/ with these copied HEX codes to generate JSON theme file
- used PowerPoint to generate sidebar images with theme colours and set page backgrounds with them
Data Loading/Data Transformations:
- used eDNA extended date table M code as [Dates] Extended Date Table (Power Query M function)
- marked [Dates] table as a date table
- changed all date formats in [Dates] table to dd-mmm-yyyy [by typing “dd-mmm-yyyy” into “Format” box directly]
- used eDNA DAX Clean Up tool to format all DAX measures and calculated columns https://analysthub.enterprisedna.co/dax-clean-up
- created empty tables for [Key Measures], [Admin Measures], and [Narrative Measures]; opened 2 sessions of Tabular Editor (1 each on my Challenge #7 [C7] PBIX and this file) and copied measures
- created empty tables for [Ring Chart Measures] and [Ridge Plot Measures]
- added [Last Refresh] table (used Power Query in both C7 PBIX and this file to copy-and-paste)
- added [fxNow, fxToday, fxStartDate, fxEndDate, fxFirstComplaint, fxLastComplaint] parameters (used Power Query in both C6 PBIX and this file to copy-and-paste)
- renamed [fxFirstComplaint] to [fxFirstDataDate]; renamed [fxLastComplaint] to [fxLastDataDate]
- changed [fxFirstDataDate] to use earliest [Created] date; changed [fxLastDataDate] to use latest [Due Date]
- modified [Dates] query to use now-available [fxStartDate] and [fxEndDate] parameters
- used “Properties” pane in “Model” view to hide all ID fields
- imported [jira cleaned.xlsx] as staging query [RAW Jira Tickets]; disabled load; moved into new group [Staging Queries]
- created reference of [RAW Jira Tickets] as [Assignees], chose only [Assignee] column, removed duplicates, removed empty, sorted alphabetically, added index column (from 1)
- renamed [Index] to [Assignee ID]
- added [Name] column using “Column From Examples”; duplicated column, then used “Split Column\By Delimiter” (space) to add First Name] and [Last Name]
- created reference of [RAW Jira Tickets] as [Creators], chose only [Creator] column, removed duplicates, sorted alphabetically, added index column (from 1)
- renamed [Index] to [Creator ID]
- created reference of [RAW Jira Tickets] as [Priorities], chose only [Priority] column, removed duplicates, sorted alphabetically, added index column (from 1)
- renamed [Index] to [Priority ID]
- created reference of [RAW Jira Tickets] as [Projects], chose only [Project key], [Project name], [Project type], and [Project lead] columns, removed duplicates, sorted alphabetically, added index column (from 1)
- renamed [Project key] to [Project Key], [Project name] to [Project Name], [Project type] to [Project Type], [Project lead] to [Project Lead], [Index] to [Project ID]
- created reference of [RAW Jira Tickets] as [Reporters], chose only [Reporter] column, removed duplicates, removed empty, sorted alphabetically, added index column (from 1)
- renamed [Index] to [Reporter ID]
- created reference of [RAW Jira Tickets] as [Resolutions], chose only [Resolution] column, removed duplicates, removed blanks, sorted alphabetically, added index column (from 1)
- renamed [Index] to [Resolution ID]
- created reference of [RAW Jira Tickets] as [Status], chose only [Status] column, removed duplicates, sorted alphabetically, added index column (from 1)
- renamed [Index] to [Status ID]
- created reference of [RAW Jira Tickets] as [Types], chose only [Issue Type] column, removed duplicates, sorted alphabetically, added index column (from 1)
- renamed [Issue Type] to [Type] and [Index] to [Type ID]
- created reference of [RAW Jira Tickets] as [Issues]
- renamed [Issue key] to [Issue Key], [Issue id] to [Issue ID], [Parent id] to [Parent Issue ID]
- [Due Date] column was text, so renamed to [Due Date (text)], then split column on [space] into [Date], and [Time]; deleted [Time]; split [Date] on [hyphen] into [Year], [Month], [Day]; merged [Year], [Month], [Day] into [Due Date]; replaced “–” with blank; changed column type to “Date”
- merged [Issues] table with [Assignees] table, keeping only [Assignee ID] column and removing [Assignee] column
- merged [Issues] table with [Reporters] table, keeping only [Reporter ID] column and removing [Reporter] column
- merged [Issues] table with [Creators] table, keeping only [Creator ID] column and removing [Creator] column
- merged [Issues] table with [Priorities] table, keeping only [Priority ID] column and removing [Priority] column
- merged [Issues] table with [Resolutions] table, keeping only [Resolution ID] column and removing [Resolution] column
- merged [Issues] table with [Status] table, keeping only [Status ID] column and removing [Status] column
- merged [Issues] table with [Types] table, keeping only [Type ID] and removing [Issue Type] column
- merged [Issues] table with [Projects] table, keeping only [Project ID] and removing [Project key], [Project name], [Project type], and [Project lead] columns
- changed datatype of all date columns in [Issues] table from “Date/Time” to “Date”
- changed date format of all date columns in [Issues] table to “dd-mmm-yyyy” [by typing “dd-mmm-yyyy” into “Format” box directly]
- Issues:
- changed [Parent Issue ID] data type to “Whole Number” so could combine with existing “Whole Number” [Issue ID] in next step
- used Parent-Child DAX pattern (https://www.daxpatterns.com/parent-child-hierarchies/#) to combine [Issue ID] and [Parent Issue ID] into new [IssuePath] column
- used Parent-Child DAX pattern (https://www.daxpatterns.com/parent-child-hierarchies/#) (again) to split [IssuePath] column into separate [Level1] and [Level2] columns
- created DAX table for [Watchers]
- extracted all values for [Issue ID] and [Watchers], [Watchers], [Watchers_4], [Watchers_5], [Watchers_6], [Watchers_7]
- added calculated columns for [Name] without domain; set to proper case; added calculated columns for [First Name] and [Last Name]
- added supporting table for SLA (service level agreements), and made-up data for overall and priority-specific SLA’s
- added supporting table for Python Ring Chart ring colours and data labels
- added supporting table for Python Ridge Plot area chart colours and data labels
Data Model:
- deleted all relationships auto-generated by Power BI
- arranged tables into “waterfall” layout, with lookup tables at top, fact table at bottom, measure tables at top-right, and supporting tables at bottom-left
- created 1-to-many relationships:
- Assignees[Assignee ID] → Issues[Assignee ID]
- Reporters[Reporter ID] → Issues[Reporter ID]
- Creators[Creator ID] → Issues[Creator ID]
- Priorities[Priority ID] → Issues[Priority ID]
- Resolutions[Resolution ID] → Issues[Resolution ID]
- Status[Status ID] → Issues[Status ID]
- Types[Type ID] → Issues[Type ID]
- Projects[Project ID] → Issues[Project ID]
- organized all [Admin Measures] into subfolders using Model view as displayed in @JarrettM’s video https://www.youtube.com/watch?v=J_qZ_S-ghoc
DAX Calculations:
- added “Admin” measures for:
- [Is Desktop] using difference between NOW() and UTCNOW() to determine user interface
- [Is Service] using difference between USERNAME() and USERPRINCIPALNAME() to determine user interface
- [… Tooltip] measures to use [Is Desktop] and [Is Service] to display the appropriate tooltip regardless of interface
Visualizations:
General:
- used same-size, different colour sidebar on all pages
- generated sidebars using theme colours [25% darker for sidebar colours (#0B3961, #48658D, #818E96)] and static text in PowerPoint, and exported slides as PNGs, then used as page backgrounds
- used buttons with less-than and greater-than signs (button text font=DIN, size=30 pt, padding=0) as back and forward chevrons at top-left of sidebar for navigation
- used changing colours to improve “bounce” (from grey default to white-on hover), similar to Microsoft Teams
- used multi-row card for Version and Report ID in bottom-left corner
- used smart narrative textbox in bottom-right corner for last refresh date (static text and dynamic measure for last refresh date)
- made text as small as possible and set style to italics
- used button with “Information” icon in top-right corner to allow the Info Tooltip to be displayed (when mouse is hovered over icon, then question mark icon appears below, which in turn when hovered-over display “Info Tooltip” page
- used changing line colours and line weights to improve “bounce” (from light grey default to darker grey on hover)
Info Tooltip:
- in Visualizations pane, Format section, set “Page Size” to [Tooltip]
- in Visualizations pane, Format section, set “Page Information \ Tooltip” to [On]
Summary:
- used standard multi-row card to show metrics
- used smart narratives textbox to display custom static text and dynamic measures; created a [Narrative Measures] measure group to hold the measures I wanted to include so I could both find them easily and set their formatting how I wanted without impacting the main report
- added standard Python visual and configured as a Ring Chart displaying high, medium, and low priority issue resolution vs. SLA performance
- adjusted transparencies (did you know you can use “#FF000000” as a colour in Power BI to “colour” something transparent?)
- the legends available in the handful of Python charts and plots I sampled are quite different in layout than those in standard Power BI visuals, so a standard Power BI donut chart was created and used with same measures and colours as the Python Ring Chart, and the title was removed and the height was reduced until only the legend was visible, then this visual was overlaid on the Python Ring Chart to create a consistent legend; further, the ring chart and the standalone legend were grouped in the Selection Pane so their visibility z-order would stay the same and they would be moved as a set
- couldn’t figure out how to add the percentages themselves into the Python Ring Chart, so created 3 standard Power BI Card visuals, set 1 each to each of the 3 percentages, and overlaid them on the Ring Chart
- used standard column chart to show issues by year and priority category
- used standard column chart to show issues by year and status category
- used standard column chart to show issues by quarter and type category for this year and last year (used filter pane to add visual filter for [YearOffset] of -1 or 0)
Current:
- used a standard date slicer
- used page filter for “Month Offset” between -1 and 1 to show a three-month period centred on this month
- used a standard pie chart to present issues by status category to determine the relative size of the current backlog vs. the current work-in-progress
- used a standard doughnut chart to present issue type, checking for the relative volume of bugs/fixes and internal process vs. other types of issues
- used a standard line chart to display the number of issues for each “assignee” during the current period; filtered the chart to display only those “assignees” who were assigned more than 2 issues
- used a standard bar chart to display the number and priority of issues assigned to each “assignee” in the current period
Analysis:
- used a smart narratives textbox for “Notes”
- used a smart narratives textbox for “Follow-up”
