I’m a bit of a newbie. For the Power BI challenges, do we get to see the winners data models / visualisations etc? This would be an incredible learning resource for beginners like myself.
Hello @danielt
Please see if this helps: Power BI Challenge Showcase
Yes, that’s very helpful thank you.
Hi @danielt if you can mark @dileepkvme reply as a solution that would be great, thanks.
David
Hi David,
I’m new and don’t know how to do that.
Hello @danielt …
Hope this will also be of interest to you:
PBI Challenge Webinar/Course Details
Hello @danielt, just following up if the response from @Harsh help you solve your inquiry?
We’ve noticed that no response has been received from you since a few days ago. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hello @danielt. You can mark a post a solution by clicking the 3 dots on the lower right corner of the response that solved your question and tick the solution box.
See image below:
You may check this how-to guide to help you navigate the forum - How To Use The Enterprise DNA Support Forum
@danielt due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, you can create a new thread.
