Many thanks @BrianJ
Thanks Brian. Shout out to @jamie.bryan for the calculation / methodology of highest and lowest State. Went round in circles with min, max and if. Withdrew the model to try again. Still no luck!
Ended up practicing the use of VAR to reduce one off measures.
Great challenge and learnt a huge amount. Thanks to everyone who helped set it up.
EDNA Power BI Accelerator â Week 3 Problem Final.pbix (14.3 MB)
hanks
LOL. Yeah, in retrospect, I probably should have covered variables first since Iâd forgotten how many extra measures you have to write if you donât use themâŚ
Really glad to hear that you found the exercise so valuable. Thanks for the feedback!
- Brian
Hello Brian:
Regarding the map visual:
- Should each Region be treated as a separate entity; that is, a top and bottom for each selected Region?
OrâŚ
- If multiple Regions are selected, should the selected regions be treated as one larger region with only one top and one bottom?
Thanks.
John Giles
John,
Good question. I envisioned it as #2, since that provides the user with more information. Otherwise, to get the min/max for each region, they could just make sequential selections in the slicer.
- Brian
Thanks, Brian:
Prompt as always.
John Giles
Hi Everyone,
To be honest still trying to get my head around this calculate function but watching the videos , seeing examples of calculate format does help. Copying the format and just applying the naming conventions that i use in my model. Just hoping put the right information in it.
Please see attached file. Any comments is welcome.
See you next week for the live solution.
@BrianJ Did you post the Registration link yet?
Keith
Well done! Looking through your report - it all looks spot on.
I honestly believe 30% of peopleâs struggle with CALCULATE is the fact that it is the most poorly named function in DAX. Only in the most abstract sense does it really have to do with calculations. If I could snap my fingers and change the name to CHANGECONTEXT(), I believe DAX would immediately make more sense to the majority of users.
Seems that youâre well on the road to a good understanding, and hopefully the live session will help shed some additional light.
Per your question, the registration info is now up on this post:
Thanks for participating!
- Brian
P.S. Happy Cake Day.
Hi @BrianJ
Thank you so much for the birthday wishes. I had a great day.
I just saw the registration come up and have register for the session. I hope you receive the information.
I appreciation your input.
Iâm looking forward to the session.
thanks again
Keith
Hello Brian:
Here is my submission for Accelerator #3.
Before going any further, I will state that I wouldnât have completed the task if it werenât for Stevens and Jamie.Bryan and their work on the Map Visual (see below).
This Accelerator was a challenge, certainly.
I figured out the Cumulative, Mode and Average Visuals, quickly enough, unless you tell me something differently. The Map was a real struggle.
I went through MINX and MAXX and RANKX. At one point, I thought I had the answer with RANKX. Everything looked fine on the tables I used to test. However, it all fell apart on the Shape Map and the Diverging colors.
I worked with TOPN, but couldnât figure out a way to return the Top and Bottom states until I referred to Stevenâs and Jamieâs solutions with the +1, -1 for the Top and Bottom.
I thought Iâd add a Tooltip to the Map for the State Ranking within ALL states and the State Ranking within ALLSELECTED states. I thought it would be easy, the ranking within all states is fine, the ranking with ALLSELECTED states, doesnât work. More to be learned regarding context.
Regards,
John Giles
EDNA Power BI Accelerator â Week 3 SAVE.pbix (9.7 MB)
@JohnG ,
âI figured out the Cumulative, Mode and Average Visuals, quickly enough, unless you tell me something differently. The Map was a real struggle.â
Nope, you nailed all of those spot on. Well done!
A word to all about the map visual. That one is giving a lot of folks fits. Itâs actually a bit of an unfair question because it requires two things we havenât discussed yet (iterating functions and conditional formatting), and I semi-regret putting it in there. The challenge with Accelerator is that we have folks with a pretty wide range of experience and skills participating (which is awesome!). I included the map exercise to give participants at the high end something to chew on if they blew through the first three parts quickly.
However, if youâve successfully completed the other three, then youâve achieved what we hoped you would have pertinent to the primary concepts we wanted to focus on this week. If you still have time and motivation to wrestle with the min/max profits map exercise, by all means go for it but definitely treat it as an optional âextra creditâ exercise.
- Brian
Thanks, Brian:
I followed Samâs advice and tested all my measures via Tables before applying them to their respective visual. Good advice, but still a no go with the Tooltips which I thought might take 5 minutes. Still with much to learn with Context.
John Giles
John,
Weâll dive deep into ranking in Accelerator #4, since thatâs on of the most commonly used and important iterating (âXâ) functions. Row context and iterators are going to be a focus of #4.
Note: if you search for posts on the forum using RANKX and ALLSELECTED, youâll see that that combo causes a LOT of problems. ALLSELECTED actually has some very subtle and deep complexities associated with it. Even Russo and Ferrari have stated that in the past there were some things about that functon that even they didnât fully understand, and they have said that by a wide margin it is the most difficult function in all of DAX to completely compehend. Unfortunately, unlike many other DAX functions that you can sidestep by just using different functions, this one has no complete substitute - weâre all stuck with it.
Iâve used this analogy before, but ALLSELECTED is like the volatile, unstable crew member in every heist movie (think Jeremy Renner in The TownâŚ). Necessary, because they possess a certain unique skillset, but also the one most likely to get all the other crewmembers killedâŚ
If youâre inclined to take a deep and difficult trip down the ALLSELECTED rabbit hole, here you go:
- Brian
Brian,
Hello. Here is my submission for the Accelerator #3.
Yet another great challenge. I have plenty of DAX work ahead of me. I reviewed other submissions to get me past the finish line. Looking forward to the solution review.
EDNA Power BI Accelerator â Week 3 Problem Brad Boehnke.pbix (9.7 MB)
Thanks,
Brad Boehnke
Also had a bit of fun using the following format measure on the top left graph.
+ive/-ive Formating =
SWITCH( TRUE(),
[Above or Below Average Profit] >=3, â#229f71â,
[Above or Below Average Profit] >=-30, BLANK(),
[Above or Below Average Profit] <100, â#f73700â )
Cannot remember whose youtube clip it was on but it has been really useful to someone who does not like playing with the conditional formatting colour bar.
In the conditional formatting menu select FORMAT BY - Field Value and then select the measure.
Its worth noting that BLANK uses the original colour selection so make sure that is selected in the graphic before connecting the measure.
In the measure above the positive is green and negative red.
@stevens ,
I picked up that trick a while back from @JarrettM, and now do 95%+ of my conditional formatting that way.
An additional cool trick you can add to that is controlling the transparency of the color with two more digits added onto the end of the hex code. See this thread for example:
- Brian
Very cool, will look to use it.
Have you come across this one before? It highlights lowest and highest within a range. This formula is set up for months in year. I find it useful when the data is of a similar size and you need the high lows to stand out. Learnt from one our EDNA members.
Highest Value =
VAR highestvalue = MAXX( ALLSELECTED( Dates[Month & Year], Dates[MonthnYear] ), [Total Sales] )
VAR lowestvalue = MINX( ALLSELECTED( Dates[Month & Year], Dates[MonthnYear] ), [Total Sales] )
return
if ( [Total Sales] = highestvalue, â#229f71â,
if ([Total Sales] = lowestvalue, â#f73700â ))
Hello Brian:
I havenât received the registration for this weekâs session to review Accelerator #3.
John Giles
@JohnG ,
Thanks for letting me know. We are definitely having some problems with the automatic email responses on the registration system. I will talk with the @EnterpriseDNA team and confirm you are on the registration list, and make sure that the emails with the connection link go out in timely fashion to all members registered.
â Brian
Thanks, Brian.
