Effective KPI Visuals
Hi
I’m looking for ideas on how to effectively display KPI’s and the progress based on year to date results compared to target value (kpi). As well as to show where there is a % difference in a visual where there is a shape (arrow) or image that points in one direction when the result is positive and the opposite direction when the % difference reult is negative. I recall seeing this in one of Sams tutorials but i cannot remember which one.
Any help appreciated.
@AoakeP,
Take a look at this thread:
I like the Power KPI visual. Also, here’s the first part (of 4) of an excellent blog/video series on creating KPIs in Power BI:
Hope this is helpful.
Thanks Brian
I’ll check it out
Cheers
Paula
Hi @Aoake, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!"
4 posts were split to a new topic: How to show different metric details per each row within a same column
