Here comes my question… I can see that they structure the KPI Scorecard through a matrix visualization, but I am still wondering how they do to show different metric details per each row within a same column.
For example, the Total Value column shows a Sales amount metric, Return % amount, etc.
It looks like many DAX measure for a same column…
I can’t say for certain how they did it given it’s been a while since I watched those videos, but here’s how I would do it (and I strongly suspect they took a very similar approach):
develop a separate measure for each row
develop a master measure using SWITCH(TRUE()) to call the proper measure from the set developed in 1) above, based on the SELECTEDVALUE of the Metric Name field
drop the master measure into the Values well of the matrix visual
rinse and repeat for each column in the matrix
Here’s an excellent video explaining the SWITCH( TRUE()) construct:
I hope this is helpful. Just give a shout if you have any additional questions or need more specifics.
I also got my answer from Havens, I quote: “I used a DAX generated table to create a column for each metric, then used a measure to identify the filter context for the matrix table and return one of X values depending on which category row it was on.”
For now I have built my Scorecard this way. Maybe later, I will change it into the matrix way, will let you know
