Drill through filter based on a measure
The goal is to setup a drill through filter on the table for the page Expenditure that will do the following:
There are two pages Expenditure and Thorough Table in the Pbix file.
Example: When we right click on January Months Amount (50) for Expenditure Description Food → Drill through → Thorough Table
In the thorough table it should only display January month’s (selected month’s) data not all the months Expenditure.
Note: The scenario shown here is just for example purpose. We cannot use the month column for the table, we must use measures and need to do the drill through filter to display the individual values that compose the result of the measure.
Pbix File : https://drive.google.com/file/d/1vJ5gc5kTFXKb0Yup95gApyZus2_I2Mt8/view
Expected Output :
Best Regards,
Ajinkya
Hi @ajinkyakadam0009,
Thank you for providing a sample file :+1:
The way you have it set up right now there is no context for the date table upon drill through so you have to recreate that. Found something that works, which I hope will work for you.
Here’s what I’ve done.
  1. Created a supporting table for the lay out with no relationships to your model.
  2. Created a measure to get the values in the matrix
  3. Created a measure for capturing the month context
  4. Updated the designated Drill through page
    Removing the Date from the Fact table and bringing in the Date from the Date table
    Adding the month context capturing measure to the visual level filter section
Here’s your sample file. Drillthrough_Scenario.pbix (41.3 KB)
I hope this is helpful.
Hi @ajinkyakadam0009, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
