Here’s my solution to this workout, where I used several Deneb/Vega-Lite features, including:
• title block complete with subtitle
• used a transform block to extend the dataset by performing in-visual calculations to convert the percent value to radians
• used a params block to enhance the dataset with size and position settings and calculations and to house the colour: input widget
• used a layer block with 4 marks (in background-to-foreground order):
- donut background (arc mark, 100% size, colour as selected from the colour widget, opacity = 0.3
- donut foreground (arc mark, percent size, colour as selected from the colour widget, corner radius 1/2 of the donut width)
- percent value (text mark, Power BI formatting)
- percent label (text mark, Y-position lowered by 20 pixels)
Here’s the code:
"title": {
"anchor": "start",
"align": "left",
"offset": 10,
"text": "Deneb Workout 03",
"font": "Verdana",
"fontSize": 16,
"fontWeight": "bold",
"fontStyle": "normal",
"subtitle": "KPI Donut Chart",
"subtitleFont": "Verdana",
"subtitleFontSize": 12,
"subtitleFontWeight": "normal",
"subtitleFontStyle": "italic"
"data": {"name": "dataset"},
"height": 300,
"width": 300,
"transform": [
"calculate": "'Actual vs. Budget'",
"as": "_ratio_label"
"calculate": "datum['Actual'] / datum['Budget']",
"as": "_ratio_percent"
"calculate": "2*PI*datum['_ratio_percent']",
"as": "_ratio_radians"
"params": [
{"name": "_ring_max", "value": 120},
"name": "_ring_width",
"value": 20
"name": "_ring_outer",
"expr": "_ring_max+2"
"name": "_ring_inner",
"expr": "_ring_outer-_ring_width"
"name": "_color",
"value": "#0000FF",
"bind": {
"input": "color",
"name": "colour: "
"layer": [
"name": "BACKGROUND",
"mark": {
"type": "arc",
"radius": {
"expr": "_ring_outer"
"radius2": {
"expr": "_ring_inner"
"theta": 0,
"theta2": {"expr": "2 * PI"},
"color": {"expr": "_color"},
"opacity": 0.3
"name": "RING",
"mark": {
"type": "arc",
"radius": {
"radius2": {
"theta": 0,
"theta2": {
"expr": "datum['_ratio_radians']"
"cornerRadius": 10
"name": "VALUE",
"mark": {
"type": "text",
"fontSize": 24,
"color": "black"
"encoding": {
"text": {
"field": "_ratio_percent",
"type": "quantitative",
"formatType": "pbiFormat",
"format": "#%"
"name": "LABEL",
"mark": {
"type": "text",
"align": "center",
"fontSize": 12,
"color": "black",
"dy": 20
"encoding": {
"text": {
"field": "_ratio_label",
"type": "nominal"
Congratulations to all who participated, and good luck.
Deneb Workout 03 - KPI Donut Chart.pbix (1.4 MB)
