Dataflow in power bi
Hello,
Is there a video on this website for learning dataflow in power bi ?
If not, can you point me to a simple learning resource?
Thank you
Hi @arkiboys,
I think these posts will help you get started…
and check the documentation
I hope this is helpful.
If possible can you please place a category on your threads. Very easy to is explained in a few of the FAQ banners around the forum. Thanks
Hi @arkiboys, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
