Hello,
I have a simple table with start and end inventory number for a number of subsidories and for months
The final objective is to check if
INVENTORY END OF PERIOD N = INVENTORY START OF PERIOD N+1 for each VB BA subsidory
if yes “OK”
if no " check your input "
N = month
this table is imported in power BI and the check needs to be done in power BI
what is the best approch in power BI to get the jeb done?
using offset() window() or another pattern
see tab CHECK for the wanted result
attached the file that wil be loaded in power BI
check for inventory.xlsx (104.0 KB)
thanks in advance
Roger
