I have created a bridge table because i have two tables that are not unique.
I need to subtract dates from one table from the other table. I have tried the Related function and it is not working. Below is the model schema.
What is the best solution. I am new to power bi.
@ysherriff ,
This is tough to answer with a bit more information, but typically when subtracting one table from the other, you use the EXCEPT( ) function.
Here’s a practical example:
I hope this is helpful.
Thank you Brian. I will try this out.
