Totals values are not calculated correctly
Hi Together, I have advanced calculations which do not calculate the sum value correctly. Even with some ideas from our forum I can’t get any further. Thanks for your help
Test.pbix (936.5 KB)
What you need to use is SUMMARIZE. Here is a Measure I used to get the correct totals for one of your measures:
Total Sales Styling Appointment 2 =
SUMX (
    SUMMARIZE (
        Customer,
        Customer[Customer ID],
        "Total Sales", CALCULATE (
            [Total Sales],
            DATESBETWEEN (
                'Date'[Datum],
                [Date of First Purchase Styling],
                [Date of First Purchase Styling] + 4
    [Total Sales]
Here is a great video to watch:
@Mario,
Please take a look at this thread below. I believe it addresses the identical problem you are having.
If you still have trouble after working through this, just give a shout.
Two replies at the same time. Apparently, @JarrettM just types slightly faster…
Interesting variation in approaches that gets to the same end result.
So many thank. It´s a great solution and works fine.
