Stock Aging and FIFO Valuation
Hi All,
I am presently working on a Stock Ageing Report that I have got so far with thanks to a Philip Seamark article and @Melissa on this forum.
I have looked and tried to implement the following:-
I can Calculate Stock on Hand and Cumulative Totals but I am struggling to Age the Stock and also get a Value for that Aged Stock.
eg. I know I have 4 on hand with 3 being an Age of 0 and 1 with an Age of 3 Months but I cannot seem to calculate those numbers.
Please find attached the Workbook and any help is gratefully appreciated.
The Excel file is the theory of how I want it to work.
Chris
StockFifo.pbix (102.6 KB)Edna.xlsx (20.2 KB)
Hi @chris.turnbull, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hello @chris.turnbull, due to the length by which this post has been active, we are tagging it as Solved. For further questions related to this post, please make a new thread. When starting a new post, I suggest linking this thread, provide as much context to a question as possible and include the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. Thanks!
