Hi there,
Could someone please help me in writing the dax for the 3 calculated columns as shown below? My data looks like this: mydata.xlsx (10.4 KB)
Many thanks in advance,
Michelle
Hi there,
Michelle
Its easy in Power Query. Let me know if you need only in DAX
Create duplicate column and split column by delimiter .
Hello Rajesh, thank you for your reply. However, I need a calculated column formula as I cannot use Power Query.
Hi
I attached a step by step on the Poer Qury transformation that may help on the split .
Luca
009-PowerQueryVariousTips.pdf (1.6 MB)
@BrianJ Amazing resource shared by Luca that can be shared with forum members for troubleshooting general issues.
Thanks Luca - - - i need the Dax forumal
for the dax is there any limitation on words?
I would use a combination of Left/Right with search dax functionβ¦
I done once for splitting a the Name filed into the two Given Name and Family Name.
Otherwise, I think should use SQL and some playing with the table
lb
A couple of questions:
will there only ever be a max of 2 β-β delimiters?
will the dashes always have a blank space to the left and right of them?
Just want to make sure we wonβt be providing an overly specific solution based on a small # of observations.
Thanks.
Have you given any consideration as to why you have to use a calculated column? If you are forced into a calculated column you could possibly make extra columns to have helper columns, but your model loses efficiency with wider columns.
here the example for the first word
1stWord-02 =
left ( Table1[Split This],
search ( " " , Table1[Split This], 1 , BLANK() )
with serach i get the position of the first space, and then i get the left side of the text
lb
@michellepace Try this:
Michelle.pbix (22.3 KB)
Table =
VAR Temp =
ADDCOLUMNS ( Michelle, "@Parent", SUBSTITUTE ( Michelle[Value], "-", "|" ) )
VAR NewColumns =
ADDCOLUMNS (
Temp,
"@FirstLevel", TRIM ( PATHITEM ( [@Parent], 1, TEXT ) ),
"@SecondLevel", TRIM ( PATHITEM ( [@Parent], 2, TEXT ) ),
"@ThirdLevel", TRIM ( PATHITEM ( [@Parent], 3, TEXT ) ),
"@FourthLevel", TRIM ( PATHITEM ( [@Parent], 4, TEXT ) )
VAR Result =
SELECTCOLUMNS (
NewColumns,
"Original", [Value],
"First Level", [@FirstLevel],
"Second Level", [@SecondLevel],
"Third Level", [@ThirdLevel],
"Fourth Level", [@FourthLevel]
Result
Similar can be done on β-β but how many level of β-β need to be split?
lb
otherwise can compute the number of instances to make the split with
NbrInstances =
LEN ( βTableβ[Original] ) -
len ( SUBSTITUTE( βTableβ[Original] , β-β , ββ )
Hi everyone. Thanks very much for your replies. But I still donβt have the solution I need. I am actually working in SSAS so my requirement really is - - create 3 calculated columns off of 1 existing column in my table. I have managed to get as far as the below. But my code breaks as soon as I have missing hyphenβ¦ I am struggling to get that part working - can anyone please help?
col1:=
VAR firstHyphen = FIND ( β-β, DimItems[temp], 1, 99 ) //4
SWITCH (
firstHyphen,
0, DimItems[temp],
TRIM ( MID ( DimItems[temp], 1, firstHyphen - 1 ) )
col2:=
VAR firstHyphen = FIND("-", DimItems[temp], 1, 0) //4
VAR secondHyphen = FIND("-", DimItems[temp],firstHyphen + 1 ) //10
SWITCH (
firstHyphen * secondHyphen,
0, ββ,
TRIM( MID(DimItems[temp], firstHyphen+1, secondHyphen-firstHyphen-1))
col3:=
RETURN TRIM(MID(DimItems[temp], secondHyphen+1, len(DimItems[temp])))
Hi @michellepace.
Hereβs another DAX possibility using 4 measures. Count the number of delimiters and then process accordingly.
Delimiter Count =
VAR _CurrentStringToSplit = SELECTEDVALUE( Raw[String to Split] )
VAR _Delimiter = " - "
VAR _DelimiterCount = DIVIDE(
LEN( _CurrentStringToSplit ) - LEN(
SUBSTITUTE( _CurrentStringToSplit, _Delimiter, "" )
LEN( _Delimiter )
_DelimiterCount
String 1 =
VAR _FirstDelimiter = FIND( _Delimiter, _CurrentStringToSplit, 1 )
SWITCH(
TRUE(),
[Delimiter Count] = 0,
[Delimiter Count] >= 1,
MID(
1,
_FirstDelimiter - 1
BLANK()
String 2 =
_Delimiter,
1,
-1
VAR _SecondDelimiter = FIND(
_Delimiter,
_FirstDelimiter + LEN( _Delimiter ),
-1
IF(
[Delimiter Count] = 2,
MID(
_SecondDelimiter - _FirstDelimiter - LEN( _Delimiter )
BLANK()
String 3 =
_Delimiter,
1,
-1
_Delimiter,
-1
IF(
MID(
_SecondDelimiter + LEN( _Delimiter ),
999999
BLANK()
Hope this helps.
eDNA Forum - Split by Delimiter.pbix (17.6 KB)
This is freaking brilliant! Would not in a million years have thought of converting this on the fly to a Path hierarchy. Was planning to use a combo of LEFT, RIGHT, MID and SEARCH, but your approach is much more efficient and straightforward.
Mic drop by DAX Mozart!
@BrianJ the solution by @AntrikshSharma deserves a video.
Hello Rajesh, thank you very much for your reply. It was 99% of what I was after. Except there are a few little errors (by 1 character either way). This solution works for me perfectly:
col1:=
VAR firstHyphen = FIND ( β-β, DimItems[temp], 1, 0 )
IF (
firstHyphen = 0,
DimItems[temp],
col2:=
VAR secondHyphen = FIND ( β-β, DimItems[temp], firstHyphen + 1, 0 )
IF (
firstHyphen = 0,
ββ,
IF (
secondHyphen = 0,
TRIM ( MID ( DimItems[temp], firstHyphen + 1, LEN ( DimItems[temp] ) ) ),
TRIM ( MID ( DimItems[temp], firstHyphen + 1, secondHyphen - firstHyphen - 1 ) )
IF (
secondHyphen = 0,
ββ,
TRIM ( MID ( DimItems[temp], secondHyphen + 1, LEN ( DimItems[temp] ) ) )
sorry that is quite vain - I marked my own solution as the solution
