Neither measures nor virtual tables will help you here. Power BI does not allow you to slice on a measure, and virtual tables exist only within the context of measures.
The other way to do this outside the filter pane is to use a calculated table such as
You could then connect that table to your data model and drop the binCode field into your slicer, without having to use the filter pane, but I’m not sure that that represents any significant advantage.
I hope this is helpful.
Brian
PS – for a deep dive into the differences between physical tables, calculated/DAX expression tables and virtual tables, you may want to check out the following video:
But in terms of performance, which method would be more suitable? Plus in the video also it mentions generally to stay away from calculated tables/ columns. So I’m leaning towards what I’ve done previously.
I think the filter pane approach you’ve taken is the way to go. Simpler, doesn’t complicate your data model, doesn’t add an extra table to the load time, etc.
I haven’t tested the two approaches against each other in Performance Analyzer, but I suspect the differences would be negligible. Would be easy to test though - open a blank page with two slicers.
Just have a visual-level filter on one slicer, and build the other from the relevant column of the calculated table table and measure the elasped timing as both refresh.
FYI - for some reason, the filter pane gets mad disrespect from a lot of Power BI users, who tip toward DAX-based solutions instead. Here’s a comparison I did last year where one line of DAX and the filter pane accomplished the same thing that it took DAX alone 59 lines to do. I’ve always taken the approach that the best and fastest DAX is the DAX you don’t have to write (even though I love writing DAX…)
