Slicer - selecting multiple selections using shift
I’m moving a report from Excel to Power BI.
In Excel the users can select multiple items in a slicer by clicking on one item, holding down [shift] and then clicking another item. All the items in between are selected.
For example click 1, then hold shift and click 5 and everything in-between is selected.
Is there a way to do the same thing in Power BI?
Hello @BillK,
Thank you for posting your query onto the Forum.
To do like this in Power BI there are 2 options available under the “Selection Controls” option -
  1. Multi - select with CTRL or
  2. Show “Select All” option. By enabling this you can select all the items at the start and de-select the items which you don’t want to show as result.
  3. You can turn off all the options and then select the multiple items. The only difference between option 2 and 3 will be you won’t be having the “Select All” Option therefore you’ll required to select all the items manually.
But what you’re trying to achieve using the Shift option is not applicable in Power BI.
I’m attaching the screenshot below for the reference.
Select date using shift option
Hoping you find this useful.
Thanks & Warm Regards,
Harsh
Hi @BillK, did the response provided by @Harsh help you solve your query? If not, how far did you get and, what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
To the contributor of this post. Thank you for sharing your experiences around Power BI, please don’t hesitate to add more discussion or add value to wherever you think you possess the experience or knowledge that can help others in our Ecosystem Group. You can also help us in improving the Support forum further by answering the Enterprise DNA Forum User Experience Survey. We appreciate the initiative and your help in this group!
