So I have a single table (FactSales) with Sales Value and Profit.
The issue is everyone can see sales for their region
However I want some users to be able to view sales but not profit.
My plan was
Create a cut down version of FactSales called FactProfit
Remove the column Profit from FactSales
Join FactSales to FactProfit
Then the I was hoping I could do like a SQL left join so if there is a value for Profit shpow it. If not zero it.
However in the model it will not let me filter in one direction for a one to one relationship. So when I run a query the security on the profit table means I get no results back from my Sales Table.
Is there a way to deliver Column Level Security In any way \ shape ?
E
Watched it. I was thinking there might be a way to mix perspectives and security but at 10 minutes in Patrick says “they are not for security. They are not a security feature”.
If there is a way for the users to see the Profit they will find it. I am truly looking for a way to secure this data.
I am working on an alternative way but that will take up space in the model and my model is already at bursting point.
@Heather
Thanks . I had missed the last articvle there. As my report cant cope with the volume of data I cant see unpivoting will work.
My current tack is to splt the fact table into two. The profit just having the Surrogate key and Profit. Then I can join to the fact table. The new profit table has one row with zero for profit and one row with the real value.
This should work but I just cant get the data into the model. Its timing out again.
E
@Rajesh
Thanks - that has sent me down a different train of thought. When I show profit if I could dispaly zero for people without permsiion and the real value for people with permission that might work.
I need to be carefull as it must be secure and also must not break any visuals which contain profit.
Ok, the method posted wont work (unless I read the post wrong) due to volumes of data. I have real performance issues so anything that adds to size of the model in a substantial way is not an option.
Thanks,
I think this will be our solution as I dont think we can add anything else into the data model. Its not ewhat I really want but I think the perfect solution would add too much to the data model size
