I need help with getting result in Power BI replicating yellow highlighted column in Excel file.
The calculation requires to get running total of all “distribution types” except “Investment” & “Payment” but in all dates with rows showing “Payment” it should keep showing “Investment” till any other type is found and then it should consider that in the calculation and reset to that value.
I have made some progress but unable to add the value after other type row is there and reset rest rows to that value.
Please refer calculated columns in “Distribution” table (“Total Invt” & “Total Others”) and measure “Running Total Others” for this for my progress so far.
While waiting for other members to jump in, I suggest using the forum search to discover if your query has been asked before by another member. Thanks!
