Hello nice to meet you, I’ve been struggling with DAX for the last few hours, I hope you can help me. I have a single Table with Codigo_Casos, VAN DISTRITAL, Temperature Category, Concentrator Type Category, and other categories. The idea is to have a bar chart that shows the Cases (CODIGO_CASOS) and their NPV value, and that with several filters leaves cases according to filtered category, but I need to place The difference between each bar value of the chart .
It’s like calculating current value minus previous row, but when using an index as a reference, it fails when I use the filters since it’s a static index. To do this, I created 2 columns calculated using RANK to create index columns that will vary according to the “Concentrator Type” Filter and the measurement in that case works PERFECT.
Here is my measure
Diferencia_Categorias__ =
VAR CurrentValue = SELECTEDVALUE(‘Resumen’[VAN Distrital])
VAR TipoConcentradoraSeleccionada = SELECTEDVALUE(‘Resumen’[Tipo_Concnertadora])
VAR Diff =
IF (
MAX(‘Resumen’[Index_0]) = 0, // Verifica si ‘Index_0’ es igual a cero
0, // Si es así, establece la diferencia como cero
CurrentValue - CALCULATE(
SUM(‘Resumen’[VAN Distrital]),
FILTER(
ALL(‘Resumen’),
‘Resumen’[Index_2] = MAX(‘Resumen’[Index_0]) && // Category filter condition
‘Resumen’[Tipo_Concnertadora] = TipoConcentradoraSeleccionada // Additional filter condition
IF(
Diff = VALUE(CurrentValue),
0,
Diff
The problem is that I have to apply more filters and the index columns fail. Create 2 measurements, filas_0 filas_2 that show what the indices should look like, with all the filters applied. Here’s the measure.
filas_2 = CALCULATE(COUNTROWS(‘Resumen’),FILTER(ALLSELECTED(‘Resumen’),‘Resumen’[Índice]<=max(‘Resumen’[Índice])))
What I haven’t been able to do is translate the formula that works (Diferencia_Categorias__) by replacing the calculated columns index_0 - index_2 with filas_0 _2 rows that are calculated MEASUREMENTS.
Please help me. this is driving me crazy lol
I attaced pbix and excel table.
BD_VAN_DRT_DCH.xlsx (29.5 KB)
Presentacion_Casos_VAN_2.pbix (798.5 KB)
