Hi all,
I’ve setup a report from which you can create Dynamics 365 Power BI reports in minutes making use of the CDS connector.
Some additional advantages:
- No external tools like XRM toolbox required,
- dataflows compatible,
- data reduction capabilities,
- optionset display values without hacks
- ability to switch environments
- generate D365 links
The file can be found here and how-to here.
PS: will be adding more how-to’s on youtube soon (like generating links, convert to dataflows, handling multiple environments, reduce data import, …)
Hope it helps.
Regards,
Christopher
