How would I change the color of the bars in the Progress tracker? I am having difficulties sourcing how / where the code is for the green bars. Best case is that two colors are used (every other row). Thank you!
You can use named colours (like the above example), HEX codes (like the original example), RGB codes or HSL codes. See my Deneb Notes on LinkedIn for more details.
