Hi Experts,
I needed to create a Circular Performance report in Power BI. However, I cannot find the equivalent visual at Power BI. Please let me know if you have any visuals that are similar to this.
Regards
Madhan Rommala
Hi Experts,
Regards
Madhan Rommala
You can also leverage the Deneb template for donut KPI charts and adjust as per your heart’s content.
Hi @mrommala. I couldn’t resist trying out the Deneb template, and quickly came up with this:
Hope this helps.
eDNA Forum - Deneb KPI Donut Charts - 2.pbix (1.4 MB)
Thank you very much, @Greg, for your prompt response. This is exactly what I’m looking for.
Hi Greg,
Thank you for providing this information; I was wondering how you got the JSON code for the Donut KPI visual.
Is it way to acquire it? So, for the time being, I can get and update the json configurations from the file you shared with me, but I was curious about other types of visuals code.
Regard,
Madhan
Hi @mrommala. I slightly adapted the Deneb Ring Chart template I’d written manually a while ago (which, in itself, was an adaptation of examples on the Vega-Lite website). You can get ideas yourself from the examples on the Vega-Lite website or from my posts on the Deneb Showcase section of the eDNA Forum. Deneb/Vega-Lite is very flexible and permits just about anything you want, but does by design usually require manual JSON coding.
