Power BI Service Live Connection message when try to import from Power BI dataset
I have a Finance Data Model workspace with a Financial Data Model dataset.
I also have an Inventory Data Model workspace with an Inventory Data Model dataset.
I now want to try to import parts of the Finance Data Model into the Inventory Data Model.
In Power BI desktop I went to Get data and clicked on Power BI datasets
but I got this error message…
I don’t know what it means.
When I was in Excel I was able to connect to the Finance Data Model and the Inventory Data Model in the same file. I was trying to do something similar in Power BI, but ran into this problem.
Thanks,
Bill
Hi @BillK
You try with a blank Power BI and then connect with dataset first and then you can go ahead with creating the other connection, that will work for you.
Mukesh
Thanks for the reply. I found it more complicated than you suggested, but I found this post very helpful.
Hi @BillK, did the response provided by the users and experts help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
