Populating data from visual tables into SQL
Can I populate data from one of my table visualization(coming from multiple tables) into SQL?
Hi @Anu
I think yes, you’ve to download that data into excel and get that ingested into your SQL database.
I’m not a data guy, so please let’s see if someone else can answer this. But I definitely feel it can be done, maybe in a better way, than what I’ve suggested.
Thanks,
Ankit
Thanks Ankit, but I would like to have it without any manual intervention.
I have to send the data from my report to sql, and use it to perform some recursion logics there .Since DAX doesnot support recursion. And then bring it back by some means
Hi @Anu, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
