Paginated Report possibilities?
Hi all!
I have a Power BI matrix report that I would like to convert into a paginated report maintain as much of the PBI report layout as is possible. I would like to know if this is at all possible (see attached image and Excel file)?
Desired Pagenated Report Layout - Copy.xlsx (39.2 KB)
Hi @powerbideveloper ,
Have your tried DataMentor/EDNA AI Tools that is built within the Enterprise DNA Learning Platform?
Also there are a course on the Learning Portal
Mastering Paginated Reports with Diverse Report
Give it a try!!!
Data Mentor
Keith
Hi @Keith,
I’m not sure if the “Mastering Paginated Reports with Diverse Report” was a link but it took me nowhere. I had a look at the DataMentor but I’m lost about that. Would like to stay focused on my question, if possible? Thanks!
Hi @powerbideveloper,
It wasn’t link but its a courses on the learning portal that you can review.
Two courses on Learning Portal:
Datamentor can help you will a solution to your problem.
Go under Project “solution” option within Datamentor
thanks
Keith
