Is it possible to modify the (Blank) to a specific text within the axis view? The ETA column is a Date column, so I am unable to change the null values to text in the Power Query Editor.
I don’t want to filter out the Blanks because they are import to our visual, but don’t have an ETA yet.
Any help is appreciated! Thank you.
@Jackie
Do (Blanks) Bar change its position when you use filter on your page? If not, then you can use the Text Box and put on top of (Blanks) Text and name it anything you like. This fix will only work if the Bar showing the results with (Blanks) stay in its position. I think the position won’t change as it is a Text and the other are Dates and Blanks will be at the left side as long as it has values to show. In this scenarios, you will always have ETA and will always have Blanks showing so I think this could work.
I wish Power BI allowed changing the axis name. Try this method and see if this solves it.
Thank you for the idea, however I don’t think that will work as the count of ETA days will change resulting in the blank column to move throughout the visual.
Hi @Jackie, did the response provided by the experts help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
Hi @Jackie, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
