Hi @ammu,
Note that your VLOOKUP for “Last 12 Months + Budget FY 2021” pointed to the wrong index column.
See how this works for you.
let
Source = Excel.Workbook(File.Contents(FileLocation), null, true),
tSample_Table = Source{[Item="tSample",Kind="Table"]}[Data],
//additional variables declared here
FYStartMonth = 7,
CurrentDate = Date.From(DateTime.FixedLocalNow()),
IdentifyCurrentDate = Table.SelectRows(tSample_Table, each ([Date] = CurrentDate)),
CurrentYear = IdentifyCurrentDate{0}[CY],
CurrentMonth = IdentifyCurrentDate{0}[CM],
//new columns added here
InsertFYoffset = Table.AddColumn(tSample_Table, "FiscalYearOffset", each try (if [CM] >= FYStartMonth then [CY]+1 else [CY]) -
(if CurrentMonth >= FYStartMonth then CurrentYear+1 else CurrentYear) otherwise null, type number),
Add_LorN12M = Table.AddColumn(InsertFYoffset, "Last or Next 12M", each Date.IsInPreviousNMonths( [Date], 12) or Date.IsInCurrentMonth( [Date] ) or Date.IsInNextNMonths( [Date], 11), type logical),
Add_L12MandCFY = Table.AddColumn(Add_LorN12M, "Last 12M or CFY", each Date.IsInPreviousNMonths( [Date], 12) or [FiscalYearOffset] =0, type logical )
in
Add_L12MandCFY
If you add the full file path to the FileLocation Parameter list and select it, the query will be restored.
Date table extensions.pbix (47.9 KB)
I hope this is helpful.
