I think there is huge list of setting available and every month Power BI is getting updated. Though you can refer below links to get what you are looking for. It will be one time activity to do setting export per your choice and reuse it with changes.
Use Microsoft document to understand each setting and default value in json format.
Below is easy way to use the field to get your color.
Hi @jgriffit, thanks for posting your query in the Forum. A response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!"
