Hello,
i need to calculate Head Count and Full time Equivalent in one model. Details are in the image.
My main questions are also in the image. For the 2nd question, a slider would also be great.
In order to get this:
i created a sample factual with dimension client and date. Contents of factual:
The next 3 measures are related to Head count:
# Resources ALL =
VAR MinDate = MIN ( 'Date'[Date] )
VAR MaxDate = MAX ( 'Date'[Date] )
VAR Result =
CALCULATE ( -- If any order can have several rows
DISTINCTCOUNT ( factFce[id] ), -- use DISTINCTCOUNT instead of COUNTROWS
factFce[entry date] <= MaxDate,
factFce[exit date]> MinDate,
REMOVEFILTERS ( 'Date' )
Result
# Resources AVG =
AVERAGEX (
'Date',
[# Resources ALL]
# Resources EOP =
CALCULATE (
[# Resources ALL],
LASTDATE ( 'Date'[Date] )
# Resources AVG and #Resources EOP worked great, mainly the AVG one does the average without any issues.
But when i try to calculate at FTE level (HC * Activity Rate * day of leaving/nr days in the month), it didn’t work.
So #Resources FTE ALL is (at least for now) equal to #Resources ALL, and the following 2 are calculated columns because i needed to place them on columns and also to try to get the right context.
# Resources FTE ALL = -- equal to #Resources ALL
VAR Result =
Result
# Resources FTE AVG = [# Resources AVG] * factFce[activity rate]
# Resources FTE EOP = [# Resources EOP] * factFce[activity rate] * IF(ISBLANK(factFce[exit date]),1, DAY(factFce[exit date])/ DAY(ENDOFMONTH(factFce[exit date])))
So, thought HC works great, but on matrix FTE where i use # Resources FTE EOP results are bad:
- March doesn’t appear
- values are wrong - for me it makes sense to use the EOP one here because if i use the average i don’t know to what point i can control the calculation, that is, if a worker leaves on 15/3, working 14 days, if the final average with AVG is ok…
- in that sense, it seemed to me that i only needed to multiply Activity Rate * day of leaving/nr days in the month to HC in the final AVG calculated column
- if i had another dimensions, does the calculation work ok?
Thanks for any help
