Hi @datazoe I am copying you again, since you have the file.
I need the correct Avg Amount When I select the Client Name.
I have Total and Avg of the ABC, I have placed Cards and it is giving me the correct results.
But
When I select the Client’s Name from the table Below
The Average and the Total Amount is same
Showing Correct
Showing Incorrect Average when I search for Client
Please be reminded that while we encourage everyone’s participation in the forum, we don’t allow single calling out of a member to answer a question as this may discourage other users to help your inquiry.
Also, to receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread.
Thank you for reminding me, I have attached the screenshots in my earlier request and now attaching the PBIX file, hope this would suffice to respond with a solution
Hi @mohammedkhan11,
Your report works as it is expected. When you select something from other visuals it applies that selection as a slicer. As a result the average measure change. But if you want for the cards above to to keep their current value, you can just edit the interactions in Format.
Here’s the file, i did modify the interactions. If i misunderstood the request please explain more
Checkout CPB - rev
Hi @mohammedkhan11, did the response provided by the users and experts help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
