Hi everyone, I am back and looking for some guidance on data set up again.
I am undertaking a project to migrate 120 airlines financial data into a format that is BI friendly so I can move to BI reporting from excel.
I am at phase 1 and I have been going through Financial Reporting /w BI in the structured learning. I have decided to reformat the data in excel so that the data entering BI via power query is as clean as possible.
I am looking to the forum for guidance as to what might be best practise.
First off I am working with an excel databook for 120 airlines and in this excel there are a number of key inputs:
annual operational
quarterly/semi annual operational
annual income statement
quarterly/semi annual income statement
annual balance sheet
quarterly/semi annual balance sheet
annual cash flow
quarterly/semi annual cash flow
Attached is an example of the excel sheet that is currently used to track the figures. I am trying to figure out the best way to set this data up. I am looking a couple of options
a) Have a separate tab for each of the bullet sections above
I think this set up is going to be one of the most important factors as I have to transform 120 spreadsheets into this so I really want to get it right if at all possible. Any guidance or help at this stage would be greatly appreciated.
While waiting for other members to jump in, I suggest using the forum search to discover if your query has been asked before by another member. Thanks!
Thank you Ankit, yes I have the lookup tables held outside of this and they are all straight forward rather it was these large fact tables that I was not so sure. I will have quite a lot of data when I build it all out.
Thank you very much for your input
It’s great to know that you are making progress with your query @Ronan.
Please don’t forget if your question has been answered within the forum it is important to mark your thread as ‘solved’.
We request you to kindly take time to answer the Enterprise DNA Forum User Experience Survey, We hope you’ll give your insights on how we can further improve the Support forum. Thanks!
Hello @Ronan, just following up if the response from @Ankit help you solve your inquiry?
We’ve noticed that no response has been received from you since a few days ago. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @Ronan, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, you can create a new thread.
