How to use Total Value without filters?
Hi! :slight_smile:
I’ve probably got some easy problem to solve. I’ve got the meassure which is calculating like:
[Acutall Value] * [Monthy Average] * [Days Remain in Month].
Now I’ve got my result which is 333,89. I would like to show this result as cumulative value.
So I would like to divide that value by the days of actual month.
Problem is that my value is good only in Total like you can see below (2 column).
When I divide that measure by days in month it gives me stupid result (3 column). Actually it gives my result, but only in Total row :frowning:
What should I do to just take only the Total result of that measure? In the third column I would like to have values 10,77 in every row.
Seems to be a row level context issue. Try this post for some guidance.
Thanks, but I don’t think it’s that kind of issue. In that post there is a problem with wrong total value. My total is ok, what I wanna do is take that total value and in some kind of way forgot how it is calculating, just want to use that value. Like Copy and Paste Only Values (without formula) in excel :smiley:
In other words, I want to delete row context and use that context what Total is using.
Anyone? :slight_smile:
Is it possible to use the result of a measure without retrieving information about how it is calculated? Just use the result like a normal number?
Hi @wojteq
Measures are always calculated based on contexts like Evaluation and Filter context. Any measure involving an expression like yours will never return a constant value and will depend on Contexts.
If you can share a sample PBIX file, then we will be able to help with your requirement.
Ankit J
@wojteq,
As always, @ankit is spot-on. “Defeating” that context and getting a value to display unchanged over multiple rows is harder than you might think. Here’s a thread you might find helpful where @Melissa and I provide two different approaches:
Measure that dynamically calculates first value of a time series
Hope this is helpful.
P.S. I had to work late last night so wasn’t able to tackle your other problem, but will definitely work on it today.
Thanks, those ideas from that link are very clever, but they are doing exactly the opposite, puting value from row to total :smiley: Isnt there any solution to tell PBI to use Context from Total in all the rows? :confused: It seems so simple, but it is so hard to do.
@ankit I will try to do this :slight_smile:
Perhaps try REMOVEFILTERS and remove all context filters applied by your visual?
Hi @wojteq
In Power BI, simple things are sometimes most confusing :smiley: Like SQLBI team says, DAX is simple, but it is not easy. Good blog covering complexity with DAX in comparison to excel/others.
Ankit J
@wojteq,
I set up an example that I think is analogous to what you’re trying to do:
Here’s the key measure:
Maxx Constant =
    MAXX(
        Dates,
        [Cumul Div Days Cntxt]
    ALLSELECTED( Dates[Date]  )
Please let me know if this hits the mark or not. Full solution file below.
Unfortunately no, because my value is in total, not in the maxx date.
My result is good when there is no day of month context, it’s good only for a month. So I try to use measures:
but they give me wrong answers too :confused:
Hi @wojteq,
Can you please provide a sample PBIX file?
Here is a sample PBIX file.
data forum2.xlsx (12.5 KB)
Maybe I should explain why I need this solution. I’ve got my forecast in measure “Value Forecast”. It’s ok for month contex, but you can see in table that results for each day are not usable.
I would like to show that Value Forecast cumulative but only from last blank day in that month and only for working days (In my original file I’ve got your calendar @Melissa so there is column for working days).
I need this to area chart.
The method of calculating the forecast is very important to me because it calculates the forecast for each product separately. Not all products have the same number of days with value, so I can’t count this as a whole.
Hi @wojteq,
Can you see if this is what you’re after. I chose 1 product to visualize and it’s based on a simple SUM because of the data format you’ve supplied (no PBIX with actual measures).
Value Prod 1 constant =
VAR cValue =
    CALCULATE( [Value Prod 1],
        FILTER( ALL( Dates ),
            Dates[MonthnYear] IN VALUES( Dates[MonthnYear] )
VAR dDate =
ADDCOLUMNS(
    CALCULATETABLE( VALUES( Dates[Date] ),
        Dates[IsAfterToday] = TRUE(),
        Dates[IsWorkingDay] = TRUE()
    ),  "@Value", cValue
AVERAGEX( dDate, [@Value] )
With this result
Here’s the sample file.Display total values.pbix (75.6 KB)
I hope this is helpful.
Hi @wojteq, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
Thanks @Melissa, it’s good to know that I can so quickly use total value of another measure.
But unfortunetly, that is not solving my problem. That average value is counting from my forecast value. So I would like to show that average value (34,42 in your file) cumulativily, but only from the last day when the value of my value that I’m forecasting appears.
286,22 is my actual value. 348,18 is my forecast. I want to show my forecast cumulativly but from day 27 in this case. I need this to my area chart when actual value line is connected to forecast cumulative line which is shown until the end of the month. This way I can see the potential value of the whole month cumulatively.
I’m trying to make your suggested measure cumulative but it’s not working fine.
Hi @wojteq,
Okay to have the lines touch, there has to be an overlap of 1 day. However the most simple fix would be to just project the lines on top of each other, like so:
Value Prod 1 constant v2 =
VAR cValue =
VAR dDate =
    ADDCOLUMNS(
        ),  "@Value", cValue
    COALESCE( [Cum Value Prod 1],
Then it looks like this:
I didn’t understand what you ment by
Let me know if that’s acceptable.
