Hello Sir,
I have many products. many of products are relate to like kg some of relate to liter,mg,gram,ml,pcs etc.
so my question is that how to convert them and show the value in metric ton.
Thanks in advance.
Hello Sir,
Thanks in advance.
Hi @dipeshkumar30, did the response provided by @MK3010 help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
Hi @dipeshkumar30, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
