I have fact table which consists of Monthid Column as Integer which direct connect to date dimension
Productid MaterialId monthid Balance
1 1 1 100
1 1 2 200
Requiremnet is as below:
I have two slicers one is for current month and another one is for previous month
lets say currentmonth is feb2020 and previousmonth i selected as dec2019 i want to show diff of balances for feb2020 and dec2019 and thier cumulative totals
My question:
How to achive currentmonth and previous month when the date are integers in power bi and what is the soluion for the above scenario.kindly do needful
Please see this thread, for a comparison using 2 slicers.
If you need any futher assistance.
When posting a topic with formula make sure that it is formatted to preformated text </>.
Include demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
i have only monthid column in facttable whic is lined to date dimension.
from the facttable monthid column which is interger like 1(this is lets say jan 2010 in date dimension value)2(feb 2010) and so on …
now from the facttabke monthid column i want to compare two different time periods can be calculated lets say current period is jan 2020 and previous period is dec 2019 on user selection.
It’s great to know that you are making progress with your query @amruthdna2018. Please don’t forget if your question has been answered within the forum it is important to mark your thread as ‘solved’. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
Thanks for your soluton. this is working fine but when i keeping both select month and preious month columns in the table its giving error saying “it doesnt have any relation”
how to achive this kidly do needful
All relationships in your model were bi-directional. The ones outlined in red between your dimension- and facttable should actually be Single AND One-to-Many
You’ve dragged and dropped a numeric field (Salesmount) in your table visual without creating a simple additive measure like: Sales = SUM( facttable[Salesmount] ) please make a habit of always creating Measures instead.
The multiple rows were caused by dragging facttable[classtatus] in your table visual, once replaced by Measures that issue was sorted.
For any type of analysis it’s vital to have your Model set up correctly first so please take some time to go over this course and after that move on to Mastering DAX Calculations.
This solution works to me…but when i place one slice like “Classificationstatus”, the table values are not getting filtering properly and values are not showing in table.Kindly do needful.
Customer needs classificationstatus as sliver based on the slicer selection current valure previous vaue currentclassification previousclassifcationvalues has to change
