How to Determine which Measures Are Used/Not Used for Visualizations?
How can we determine which measures are being used for data visualizations and which are superfluous? I have so many test measures and it’s caused my file to be rather bloated. I want to slim it down by deleting unused measures. How can we do this?
Thanks for posting your question @bslyew. To receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread.
@bslyew,
Take a look at the following thread, which presents a number of good options:
I also highly recommend taking a look at Monkey Tools, which is what I use to document my models. They offer a fully functional trial version that you can test out.
I hope this is helpful.
Hi @bslyew, we’ve noticed that no response has been received from you since the 14th of October. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
