But I just want 5- 7 columns in one row .Basically in a table visual, I am not able to control the no of columns. Everything appears in one single row.
One possible solution would be to add calculated columns to the data in Power Query to set [Index], [Group], and [Project in Group], then add [Group] to matrix rows and [Project in Group] to matrix columns. Here’s a 5-column sample.
Hi Anu. The matrix give you the formatting options you’re problem statement described; the only other “standard” visual I can think of in Multi-card, but I don’t think it has the formatting you’re looking for. If you can use custom visuals, try those from OK Viz or those that will display small multiples (I’ve barely used custom visuals, so take with a grain of salt…). Greg
I use the OK Viz custom visuals extensively (actually used two of them in the Enterprise DNA contest entry I submitted today) but their small multiples visual is more “card”-based ala KPIs, and I don’t think would work for your use case here though it is extremely configurable and there may be a creative way to torque it to do so:
That’s great (and actually a bit surprising…). Can you please post a screenshot and/or PBIX, since I’m curious how you got that to work for your requirement?
To the contributor of this post. Thank you for sharing your experiences around Power BI, please don’t hesitate to add more discussion or add value to wherever you think you possess the experience or knowledge that can help others in our Ecosystem Group. You can also help us in improving the Support forum further by answering the Enterprise DNA Forum User Experience Survey. We appreciate the initiative and your help in this group!
