Hi all,
I got below report and cannot calculate a correct grand total.
Some logic for calculation
- Density is a numeric parameter
- Each Warehouse has own Density Value
- CuFt = SqFt * Density
I am using below DAX for calculating CuFt for each warehouse, but I still cannot return 1,179,800 for Table total (570,000+ 380,800+102,000+102,000+25,000) instead of Depend Density
Can anyone help?
DAX Code
Capacity (CuFt) =
VAR GSW=if(SELECTEDVALUE(Warehouse[Warehouse])=“GSW”,‘WH Capacity Measurement’[WH CuFt Capacity]*‘Density - GSW’[Density - GSW Value],0)
VAR Oneill=if(SELECTEDVALUE(Warehouse[Warehouse])=“Oneill GA”,‘WH Capacity Measurement’[WH CuFt Capacity]*‘Density - ONLGA2’[Density - ONLGA2 Value],0)
VAR EOSCA=if(SELECTEDVALUE(Warehouse[Warehouse])=“EOSCA”,‘WH Capacity Measurement’[WH CuFt Capacity]*‘Density - EOSCA’[Density - EOSCA Value],0)
VAR EOSTX=if(SELECTEDVALUE(Warehouse[Warehouse])=“EOSTX”,‘WH Capacity Measurement’[WH CuFt Capacity]*‘Density - EOSTX’[Density - EOSTX Value],0)
VAR Irvine=if(SELECTEDVALUE(Warehouse[Warehouse])=“Irvine”,‘WH Capacity Measurement’[WH CuFt Capacity]*‘Density - Irvine’[Density - Irvine Value],0)
Return
if(SELECTEDVALUE(Warehouse[Warehouse])=“GSW”,GSW,
if(SELECTEDVALUE(Warehouse[Warehouse])=“Oneill GA”,Oneill,
if(SELECTEDVALUE(Warehouse[Warehouse])=“EOSCA”,EOSCA,
if(SELECTEDVALUE(Warehouse[Warehouse])=“EOSTX”,EOSTX,
if(SELECTEDVALUE(Warehouse[Warehouse])=“Irvine”,Irvine,
“Depend Density”)))))
