Hi all,
I am building below matrix and need to convert the SqFt to Capacity (CufT) (SqFt * Density).
As 2 warehouses have different Density, and I write below DAX.
However, I still cannot figure out how to get the correct total capacity.
Can anyone help? Thanks.
Capacity (CuFt) =
VAR GSW=if(SELECTEDVALUE(Warehouse[Warehouse])=“GSW”,‘WH Capacity Measurement’[WH CuFt Capacity]‘Density - GSW’[Density - GSW Value],0)
VAR Oneill=if(SELECTEDVALUE(Warehouse[Warehouse])=“Oneill GA”,‘WH Capacity Measurement’[WH CuFt Capacity]‘Density - ONLGA2’[Density - ONLGA2 Value],0)
VAR Total=GSW+Oneill
Return
if(SELECTEDVALUE(Warehouse[Warehouse])=“GSW”,GSW,if(SELECTEDVALUE(Warehouse[Warehouse])=“Oneill GA”,Oneill,Total))
Sorry for I cannot upload the PBI file now as the file size is too large
Hi @chiu2003, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
- Use the forum search to discover if your query has been asked before by another member.
- When posting a topic with formula make sure that it is correctly formatted to preformatted text </>.
Hi @chiu2003,
Thanks very much for post your query into the forum.
To fix the calculation of the measure in the totals you can create the following measures:
Capacity (CuFt) =
VAR _Density_GWS = [Density - GWS Value]
VAR _Density_Oneill_GA = [Density - Oneill GA Value]
VAR _Current_Warehouse = SELECTEDVALUE( Warehouse[Wharehouse] )
VAR _Current_SqFt = SELECTEDVALUE( Warehouse[SqFt] )
VAR _Density = SWITCH(
TRUE(),
_Current_Warehouse = "GSW", _Density_GWS,
_Current_Warehouse = "Oneill GA", _Density_Oneill_GA
VAR _Result = _Current_SqFt * _Density
_Result
Capacity (CuFt) Total =
VAR _VirtualTable =
ADDCOLUMNS(
VALUES( Warehouse[Wharehouse] ),
"@Capacity (CuFt)", [Capacity (CuFt)]
VAR _Result = IF(
HASONEVALUE( Warehouse[Wharehouse] ),
[Capacity (CuFt)],
SUMX( _VirtualTable, [@Capacity (CuFt)] )
_Result
We create the measure for the records in the table and another measure for the totals that sums all the values of the measure for each individual record.
Regards,
Incorrect Total after what-if parameter_JAFP.pbix (392.8 KB)
Hi @chiu2003, did the response provided by @jafernandezpuga help in solving your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @chiu2003, we noticed that no response was received from you with regard to our post last Oct 7th.
We just want to check if you still need further help with this post.
Hi @chiu2003, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box
