For the matrix graph, how to add an extra column that includes a sparklines for all years
Please @Harsh … for the matrix graph, when I added the sparklines to the matrix, I found it created an extra column for each, which is not the thing I am looking for.
Is it possible to create one single column that contains a cell that includes sparklines for all years as we do it in excel?
Thanks a lot for your valuable time helping me.
Hello @MGadAllah,
Power BI doesn’t works like Excel. Because in Excel that fields/visuals are added and placed manually, as per our requirements wherever we deem fit. By default, that’s not possible in Power BI and therefore, it’ll add a sparkline for each column. But you can adopt an alternative by hiding all the individual/unrequired sparklines for those columns and only retaining it at a grand total level. Here’s how you can do that -
Go to the “Format” menu >>> under that go to the “Column Headers” and disable the “Text Wrap” option. Below is the screenshot provided for the reference -
Now, perform the task as showcased in the below provided GIF -
Hiding Un-required Columns
Finally, after hiding all the un-required columns, your report will look like this -
Thanks and Warm Regards,
Harsh
Spark Lines - Harsh.pbix (3.5 MB)
Is it possible @Harsh to hide the Total Sales by Order Date column, and only keep the sparklines column?
I mean for the above visual, to have the WesternAustralia followed by the sparklines directly.
