I went through the Financial Dashboards videos and tried to do replicate the file on my own. I faced the following issues, and appreciate any guidance:
Double Calculate instead of LY value:
In the video called Time Comparison calculation, at min 6:53, it is said that instead of doing a double CALCULATE function, we can use one CALCULATE with the LY measure. I’ve used
this part above seems to be missing from your TY vs LY measure
- Again this looks simply like a formatting issue in your formula.
Currently the formula doesn’t know that the values need to be a percentage
You’ll see here below in this image from the video that your formula setup is different to the example
You need to make sure you can turn the format of the formula into a percentage.
Currently because of the above you can’t do that.
Try these things I’ve mentioned above.
Hi @dotbuilt, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
