Thank for @tholstrup for the Solution but this solution will not work for my problem since I have employee data of over 3 lakh rows and 75 Columns so if I unpivot I will end up in problem with so many rows, Therefore any alternate solution without Unpivoting is appreciated.
One potential way to do this is to use what I call a pseudo-slicer, which you can configure to look like a slicer, but is actually a series of buttons linked to page navigation actions. In this case, each button would correspond to a different column header name, and clicking on that would take you to a page using that column as your filter context in a table or matrix. You could also do it on a single page with a large number of bookmarks, but I think the page navigation option is simpler.
This thread below describes the pseudo-slicer approach in more detail, and has a publish to web link where you can play with the demo.
Hi @Dharma, we’ve noticed that no response has been received from you since September 13.
Hi @Dharma, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please create a new thread.
