For the Enterprise DNA videos, we all use Camtasia which is fantastic for screen recording and editing. It’s not cheap though, and if you’re only going to be doing this occasionally is probably overkill. However, if you’re going to be recording videos on a regular basis, I would highly recommend it. You can learn it at any level you need – I just use the basic recording, editing and annotation features and the professional editors do the rest, but if you were so inclined you could fairly easily learn some pretty sophisticated editing techniques. TechSmith, the publisher of Camtasia, offers a wide array of training videos on YouTube at all levels.
For microphones, I think we all use the Yeti. I did a lot of research, and have a really nice and reasonably priced boom arm, shock mount and pop screen set up for the Yeti (again if you’re going to be doing this on a regular basis), and would be happy to share that information with you if helpful.
Another suggestion is to record videos with Snagit, little brother of Camtasia @BrianJ mentioned and then use the Adobe Premiere Pro with monthly subscription. Pay only for the months you record and could be cheaper depending on your usage.
The software above is a great way to prepare very professional looking videos.
I will add one other option, if you need to do this quickly and cheaply, which I recently had to do.
My company uses Teams for communication (again, because we have many people currently working from home). And I accidentally discovered that you can record a Teams meeting that has no attendees other than yourself.
This will only record whatever is being viewed in the screen share (so no, it won’t record video of the speaker without some careful screen layering), and it will record audio being broadcast over Teams.
So, by ‘hosting’ a meeting in an empty Team (no other members), and talking into my computer headset - I was able to record a quick 2 minute video on how to properly change the date filter in the filter pane from relative to advanced.
It wasn’t perfect, but it worked in a pinch. The videos are saved to Microsoft Stream, you get a link to it’s location, and you can download for saving to a more appropriate area if needed.
Yeah, and they extend it for another 15 days as well as far as I remember, so after 30 days format your PC and you have another month of access! haha!!
*bows * Thank you good sir, I have worked hard to hone MacGyver skills
Working with a smaller company - you definitely learn think creatively, particularly when our IT department (2 people) keep saying that ‘they’ll get around to’ reviewing whatever software you need eventually
Honestly, I am so grateful I was able to get an install of PowerBi desktop approved in the early days of the software.
Hi @mbraun, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
