I have a sample data and wanted to group/encapsulate it based on the TopN given. In addition, I am getting a null value here showing which I think is not good idea to be included as well. Do I need to have a custom table and have a relationship into it? Attached is the sample pbix file which you can play around. Thanks for the help!
Hi @ronald_balza , we noticed you posted a modified version of the same questions as this original post:
We are marking this thread as “Solved” since your original query was solved by @Harsh on the other thread. If you have further inquiry for another topic, kindly create a new thread.
