Dynamic Image in Power BI Report
I was wondering if it would be possible to have dynamic image in your report ?
Chris
HI @chriskoetje. Please create new forum questions in a stand-alone thread rather than reply to this introduction thread. Looping in @EnterpriseDNA to split this post into its own thread.
Hi @chriskoetje, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
@chriskoetje,
Yes, this is something I do quite regularly in my reports. For examples, you may want to look at my Data Challenge entries for challenges #5 and #7. I’ve included both the screenshots and my report writeup links for how I did these below.
I hope this is helpful. Please give a shout if you have any questions.
– Brian
Hi @chriskoetje, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
