Dynamic access to report based on level
Hi All,
I have RLS applied to a report based on location.
The report has level category as A, B, C, D and E . I want to have complete access to the report for A, B, C, D based on location based RLS provided, but E should see only his data to his location.
Any idea how i should take this forward ?
stay safe,
Niraj
Hi @nbaraili,
You can refer to below blog we have very good discussion on this.
Mukesh
Hi @nbaraili, we’ve noticed that no response has been received from you since the 16th of October. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
Hi @nbaraili I ask you to see the link below I think it solves your problem or can give you an idea of ​​a resolution.
Hi @nbaraili, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!
