Deneb Workout 01 - Line Chart with Smoothing
Hi @BrianJ. I think Vega-Lite got confused with the title property being specified twice; when the 2nd was deleted, I got this:
Note as well that you do not need to specify a title at all if the desired title is the same as the field name, as Vega-Lite will use the field name by default.
Hope this helps.
@Greg ,
Thanks! - that makes perfect sense, but when I removed the second “tltle” spec and re-ran the code, I’m still not getting the x or y axis labels. :rage:
Deneb Workout 1 - Line Chart with Smoothing.pbix (9.1 MB)
Click for code
  "data": {"name": "dataset"},
  "mark": {
    "type": "line",
    "interpolate": "natural",
    "tension": 0
  "title": {
    "text": "Deneb Workout 01",
    "anchor": "start",
    "align": "left",
    "font": "Segoe UI",
    "fontSize": 16,
    "fontWeight": "bold",
    "subtitle": "Line Chart with Smoothing",
    "subtitleFontSize": 14,
    "offset": 12
  "encoding": {
    "x": {
      "field": "Order Date",
      "type": "temporal"
    "y": {
      "field": "Total Sales",
      "type": "quantitative",
      "title": "Sales",
      "scale": {"domain": [0, 60000]},
      "axis": {"tickCount": 5}
    "color": {
      "field": "Channel Name",
      "type": "nominal",
      "scale": {"scheme": "Category10"},
      "legend": {
        "title": null,
        "orient": "top-left",
        "symbolType": "stroke"
Hi @BrianJ. Yeah, I thought it might. Your code actually ran fine on my PBIX before I made any changes (just noted the doubling 'cuz it was there…), so I’m guessing there must be else something in your file; post your PBIX and I’ll have a look.
Edit: Oops … just noticed you did attach it … hold please …
Hi @BrianJ. Its the default code in the Config tab; just delete it and “presto”.
@Greg ,
Thanks - BINGO!
But where did that config code come from? I definitely didn’t put it there…
Hi @BrianJ. A new Deneb visual is defaulted with some config code. I most often delete it, but it is sometimes quite helpful, as we’ll see in some future workouts.
Hi had some troubles as well, but as I had same problems in near past I guess it could be the problem and have tried to delete each part of code step by step to understand what each part was doing.
I’m looking forward for the next challenge:)
Here’s my solution to this workout:
Deneb Workout 01 - Line Chart with Smoothing - Solution Screenshot #1
In it, I used several Deneb/Vega-Lite features, including:
  • • title block complete with subtitle
  • • line smoothing (via the “interpolate” mark property) using the “natural” algorithm
  • • set the range of the Y-axis to 0-60000 (via the “scale/domain” block in the Y-axis encoding
  • • set the approximate number of Y-axis ticks (via the “axis/tickCount” block in the Y-axis encoding)
  • • set the lines to use the current Power BI theme colours (via the “scale/scheme” block in the color encoding)
Here’s the code:
  "title": {
    "anchor": "start",
    "align": "left",
    "offset": 10,
    "font": "Verdana",
    "fontSize": 16,
    "fontStyle": "normal",
    "subtitleFont": "Verdana",
    "subtitleFontSize": 12,
    "subtitleFontWeight": "normal",
    "subtitleFontStyle": "italic"
  "mark": {
    "type": "line",
  "encoding": {
    "x": {
      "type": "temporal"
    "y": {
      "field": "Sales",
    "color": {
      "field": "Channel",
      "scale": {
        "scheme": "pbiColorNominal"
There are many line smoothing algorithms that can be used as well as “natural”, some of which also use a “tension” property. To showcase, here’s an alternate solution using screen widgets to present the “interpolate” and “tension” options:
Deneb Workout 01 - Line Chart with Smoothing - Solution Screenshot #2
Here’s the code for the alternate solution:
  "title": {
    "anchor": "start",
    "align": "left",
    "offset": 10,
    "font": "Verdana",
    "fontSize": 16,
    "subtitle": "Line Chart with Smoothing (2) -  with Screen Widgets",
  "height": 540,
  "width": 600,
  "params": [
      "name": "_interpolate",
      "value": "cardinal",
      "bind": {
        "input": "select",
        "options": [
          "basis",
          "cardinal",
          "catmull-rom",
          "linear",
          "monotone",
          "natural",
          "step",
          "step-after",
          "step-before"
        "name": "interpolation algorithm: "
      "name": "_tension",
      "value": 0.3,
      "bind": {
        "input": "range",
        "min": 0,
        "max": 1,
        "step": 0.1,
        "name": "tension value: "
  "mark": {
    "type": "line",
    "interpolate": {
      "expr": "_interpolate"
    "tension": {"expr": "_tension"}
  "encoding": {
    "x": {
      "type": "temporal"
    "y": {
      "field": "Sales",
    "color": {
      "field": "Channel",
      "scale": {
Congratulations to all who participated, and good luck.
Deneb Workout 01 - Line Chart with Smoothing.pbix (1.4 MB)
Hi Greg,
I started late with this workout. My strategy was the same I do on my real work development:
1 - Do a quick search for a possible solution to start working with
2- I find your template in Deneb Showcase: Deneb Template - Line Chart with curve smoothing - Deneb Showcase - Enterprise DNA Forum
3- I applied the JSON Template
4- I added Subtitle following the Vega-Lite documentation: View Title | Vega-Lite
5- I changed the scale to 60000
6- I changed Color to PowerBI Theme following Deneb Tutorial: Theme Colors & Schemes | Deneb (deneb-viz.github.io)
7- I couldn’t find a solution to changing SubTitle to cursive. I find in VegaLite Documentation that is on “subtitleFontStyle” but I was defining “cursive” and nothing was changing. I saw your solution and learned that it is called “Italic” and not “cursive”
8- I changed Date Format to “DD-MMM-YYYY”
  "title": {
    "subtitleFontStyle": "italic",
    "anchor": "start",
    "align": "left",
    "font": "Verdana",
    "fontSize": 16,
    "offset": 10
  "mark": {
    "type": "line",
  "encoding": {
    "x": {
      "type": "temporal"
    "y": {
      "field": "Sales",
      "axis": {"tickCount": 3}
    "color": {
      "scale": {
Hi @scancela.90. I’ve used “italic” and “normal” for the subtitleFontStyle, but have not seen “cursive”.
