A speedometer visual, due to its inherent layout, takes-up a notable amount of space. A linear gauge visual is an alternative that requires less screen real estate, and I enclose a Deneb/Vega-Lite template for such a linear gauge.
This template illustrates a number of Deneb/Vega-Lite features, including:
- “transform” blocks to filter the supplied dataset to only the rows relevant to the current mark
- a Vega-Lite setting of the approximate number of x-axis labels
- a Vega-Lite sorting of the range labels
- a Deneb custom tooltip showing only the desired dataset fields
The intent of this template is not to provide a finished visual, but rather to serve as a starting point for further custom visual development.
Also included is the sample PBIX using a made-up dataset as a demo.
NOTE 1: This template is provided as-is for information purposes only, and its use is solely at the discretion of the end user; no responsibility is assumed by the author.
NOTE 2: This template was prepared using a beta version of Deneb version 1.3 (a standalone version) for illustrative purposes only, and, as such, may contain development features that will not be in the final production release.
deneb.linear_gauge.0.2.json (5.1 KB)
Deneb Templates - Linear Gauge.pbix (2.8 MB)
