Hi
Our accounting system has an account code of five digits (specified as a text column).
I am creating a summary P & L account which we call a Group Ten Summary e.g. account codes between 10000 to 10009 are added together under group 1000.
I have attached the pbix file and if you look at the Summary P/L & B/S tab you will see the summary. Every group total work absolutely fine except the first Income group 0000.
If you look at the second tab (Profit & Loss) you will see the three income codes that comprise the group 0000 (00001, 00002, 00003) are there.
The group summary calculation is performed by a measure âTotal Group Tenâ in the Profit and Loss Measures section.
I am at a complete loss to understand why this is not working.
Any help greatly appreciated.
Best regards
Paul
Accounts.pbix (1.2 MB)
Hi Paul,
What in your opinion is the actual problem? I donât have a clear picture of what youâre afterâŚ
The results for the measure seem to be adding up - so please advise.
Thanks!
2020 result
2019 result
Thank you for your reply.
f you look at the first tab, the group 0000 is completely missing. It should contain value of 122,484.12, it being the total of the first three items in you image above.
Best regards
Paul
Hi Paul,
Hope youâve made a small typo
Just one slight change was enough, hereâs the updated measure:
Total Group Ten =
SUM( NlTransactionsPosted[Amount] ),
FILTER( NominalCode,
NominalCode[ NominalGroupTenCode] IN VALUES( NominalCode[ NominalGroupTenCode] )
I hope this was helpful.
Hi Melissa
Thank you so much for the solution. I really appreciate it.
I am getting much better at DAX thanks to Enterprise DNA and you have put another small brick in the wall of my knowledge.
Best regards
Paul
Glad I could help Paul, always a pleasure.
We all walk the same road to a town called âDAX masteryâ just keep following the trail, youâll get there!
Hi again
Could I be really cheeky and ask a supplemental question.
What I would like to be able to do is to have the Group Ten display but have a facility to click on an individual line and have it expand to all the account codes in that group.
I previously worked with another BI system where this was standard but seems a little more difficult in Power BI.
Best regards
Paul
Hi Paul,
Do you mean something like this:
If so I changed the Table into a Matrix visual
- added the NominalCodes
- toggled off Stepped layout
- enabled subtotal per row and toggled it off for NominalCode
By up- and downdrilling you can switch between the levels.
Exactly what I was looking for.
Thank you again.
Best regards
Paul
Itâs great to know that the issue has been fixed @PaulBoyes. Please donât forget if your question has been answered within the forum it is important to mark your thread as âsolvedâ. Also, weâve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
