Can you try this measure…
Monthly Average Updated =
VAr A = [Total unit Sales] //this will hold the sum/count of units as per the logic in measure
VAr B = 12 //this will always give 12. Doing this to give you average at year level.
return
A/B
//this is not a dynamic measure and will return value at yearly level only. If you wish to use it at diferent levels than i would suggest you to provide a sample pbix and the result you want to achieve.
I’m only starting to get my head around DAX and thought there would be a solution around count or Distinct Count I just wasn’t sure how to tie it together.
I really like the use of VAR to tie it all together thank you.
It’s great to know that you are making progress with your query @dean.alley. Please don’t forget if your question has been answered within the forum it is important to mark your thread as ‘solved’. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
