Hi
I’m looking to create two slicers relating to a DAX formula I’ve created.
Creation Date: > 365 Days
< 365 Days
Years Inventory: Greater than 1
Greater than 2
Greater than 3
Greater than 4
The below isn’t particularly important but would look better from a presentational purpose:
No Total Value for creation Date
No Total for Creation Days
No Total for First Movement Date when filtering by item
Inventory Example.xlsx (29.7 KB)
Inventory Test Example.pbix (226.9 KB)
Hi @olson.michele ,
While waiting for the community to review and respond to your issue, take advantage of Data Mentor. It offers a wealth of tools and resources that could provide immediate solutions and enhance your report-building efficiency.
Cheers,
Enterprise DNA Support Team
You can’t use measures directly in slicers but you can work around it by leveraging measures and a disconnected table. Generally, you’ll create a disconnected table that contains the values you want to use in the slicer. Then create a measure to harvest the selected value from the slicer. Then you need a filtering measure to apply the logic based on the slicer selection. Use the selected value to filter your data. Then you just use the values from the disconnected table in a slicer.
It can get complicated rather quickly, but you can use slicer functionality without modifying your existing data tables and filtering your data.
